That's awesome. That's kind of what I figured, but when I saw the Android tablet(? it's hard to tell whether something is considered a phone or a tablet these days) I figured that you primarily use it in place of a cluster. Did you set your port manually in your Torque profile? It connects a lot faster if you set the profile manually.
How far does the Wi-Fi signal transmit through the Wi-Fi adapter? Is it farther than the Bluetooth adapter? Also, what app do you use on the iPad to connect?
