Maybe I missed it, but your upper grill is still open, correct? You'll still get cooling through there and if you run the heat some the temps should stay in check. I know it's bad for FE but when you get to your destination leave the car idle and check under the hood to see if your fans are running. That'll tell you if you are running over normal operating temp and will only cost a few drops of gas.
-Mike
2007 Ford Focus ZX5 - 91k - SGII, pending upper and lower grill bocks - auto trans
1987 Monte Carlo SS - 5.3/4L80E swap - 13.67 @ 106
2007 Ford Focus Estate - 230k - 33mpg - Retired 4/2018
1995 Saturn SL2 - 256K miles - 44mpg - Retired 9/2014
Cost to Operate Spreadsheet for "The New Focus"
