Hi,
Originally Posted by Coyote X
Mine was pretty cheap, $25 for the camera and the 3.5" screen for $53
I did it by cutting off the base of the stock mirror then using a tube that the cameras fit inside to fiberglass into the base. After the fiberglass was strong enough I filled and smoothed it with lightweight body filler before painting it. They work pretty good and give a lot wider range than a normal mirror. The passenger side screen is a bit small but it gets the job done. Drivers side works great. Only bad thing is I have only managed to put 125 miles on the car since putting them on  I need to get out and drive some more
That's awesome stuff -- almost exactly what I was thinking of.
How wide a view does the camera have? How is it at night (with the IR LED's)? Can you move the righthand screen closer to the driver, so you can see it better?
