Old 03-21-2015, 08:44 PM   #45 (permalink)
firehawk618
97 Civic HX sedan VX trans - '98 Honda Civic LX + HX + VX
90 day: 41.9 mpg (US)
Yep, everything is sparkling clean inside. It was TOTALLY gummed / clogged up.
So guess what, I am able to get lean burn fairly easy in 3rd gear.
I have confirmed 3rd gear and 5th gear.
3rd puts me at about 37mph when it kicks in and 5th is at freeway speeds. DX gear ratios!
Ignore the wideband, I do NOT have the sensor installed yet. I am thinking about eliminating the 2nd o2 sensor and using the wideband in it's place. From what I can tell the 2nd o2 sensor runs from 0-1v which my Uego will output to the ECU.
Unfortunately the Uego gauge won't display anything higher than ~18 afr. but will data log even leaner than that.
Here's proof of leanburn in 3rd. I was able to do this many times, fairly easily.
Note* I was able to get it to kick in and out really quickly when NOT filming lol. I mean when I would make it kick out by stepping on the throttle or going into DFCO I could get it back within 3-5 seconds.
