I just installed my wideband+put it to the ecu for the secondary o2 input to it.
I do not like the results. Even in LB it never shows 0.00v on the scan gauge. The lowest I could get it to go was .15
Putting the stock secondary o2 back the way it was and will install a bung for my Uego.
Did some more light cruising, was able to get LB in 3rd gear also and when I shifted to 4th it came back within 5 seconds.
I found that if I shift when the shift light says, I'll never get LB in 3-4 gear.
