Originally Posted by Chrysler kid
If it takes a ground to light up would the power readings from the secondary 02 sensor at 0 volts illuminate the srs light for a true lean burn indicator
No that works off millivolts and tapping anything into it will skew the readings.
Hmmm, since my wide band has an output I won't be using then what you say would be possible but not connected directly to a light. Simply too much current draw.
