Old 03-22-2015, 03:36 AM   #50 (permalink)
firehawk618
97 Civic HX sedan VX trans - '98 Honda Civic LX + HX + VX
90 day: 41.9 mpg (US)
Originally Posted by Chrysler kid View Post
How many codes are you throwing, you have said egr and evap.
Won't let me view video but I would focus on the codes first, the car won't enter lean burn mode with check engine lights, and you really can't be sure everything is operating correctly
Unless I missed it I never claimed to be throwing any codes.
The only code that I did have "pending" was an egr code and all my passages are squeaky clean. If I do end up with an EGR code I will dis-assemble the EGR valve and go through it.
The EVAP questions I asked were related to the solenoid on my canister that has no plug on it and you helped me solve that.
I haven't said anywhere that I was having trouble getting into LB.
I was trying to indicate that LB has been pretty easy to get into.
Now if my MPGuino would get here. It's been ~3 weeks since I ordered it.
Ultragauge, as you all know is virtually worthless in it's MPG calculations in the HX. The second you hit leanburn and have to roll into the throttle more to maintain your speed the UG figures nosedive.
The Following User Says Thank You to firehawk618 For This Useful Post:
Chrysler kid (03-22-2015)
