didn't see any changes in git, and I'm not sure how helpful this is (since I just changed some case names and a filename or two), and there seems to be an impedance mismatch between git and mplabx, so my files might seem like they are in a strange location. But attached are the sources I used on linux. I am not intending to fork anything here, just a snapshot in time.
Also the built files are in post 1771.
here is the clean/build log if it helps too:
PHP Code:
CLEAN SUCCESSFUL (total time: 70ms)
make -f nbproject/Makefile-default.mk SUBPROJECTS= .build-conf
make[1]: Entering directory `/var/home/dave/Desktop/proj/mpcontroller/MPLABXProjects/mpcontrol.X'
make -f nbproject/Makefile-default.mk dist/default/production/mpcontrol.X.production.hex
make[2]: Entering directory '/var/home/dave/Desktop/proj/mpcontroller/MPLABXProjects/mpcontrol.X'
"/var/progs/microchip/xc16/v1.24/bin/xc16-gcc" ../../ACInductionController/ACInductionController.c -o build/default/production/_ext/1746335589/ACInductionController.o -c -mcpu=30F4011 -MMD -MF "build/default/production/_ext/1746335589/ACInductionController.o.d" -g -omf=elf -O0 -msmart-io=1 -Wall -msfr-warn=off
"/var/progs/microchip/xc16/v1.24/bin/xc16-gcc" ../../ACInductionController/UART4011.c -o build/default/production/_ext/1746335589/UART4011.o -c -mcpu=30F4011 -MMD -MF "build/default/production/_ext/1746335589/UART4011.o.d" -g -omf=elf -O0 -msmart-io=1 -Wall -msfr-warn=off
"/var/progs/microchip/xc16/v1.24/bin/xc16-gcc" -o dist/default/production/mpcontrol.X.production.elf build/default/production/_ext/1746335589/ACInductionController.o build/default/production/_ext/1746335589/UART4011.o -mcpu=30F4011 -omf=elf -Wl,,--defsym=__MPLAB_BUILD=1,,--script=p30F4011.gld,--stack=16,--check-sections,--data-init,--pack-data,--handles,--isr,--no-gc-sections,--fill-upper=0,--stackguard=16,--no-force-link,--smart-io,-Map="dist/default/production/mpcontrol.X.production.map",--report-mem
Program Memory [Origin = 0x100, Length = 0x7f00]
section address length (PC units) length (bytes) (dec)
.text 0x100 0x170 0x228 (552)
.const 0x270 0xff0 0x17e8 (6120)
.text 0x1260 0x1a60 0x2790 (10128)
.dinit 0x2cc0 0x174 0x22e (558)
Total program memory used (bytes): 0x43ce (17358) 35%
Data Memory [Origin = 0x800, Length = 0x800]
section address alignment gaps total length (dec)
.ndata 0x800 0 0x1ac (428)
.nbss 0x9ac 0 0x188 (392)
.ndata 0xb34 0 0x58 (88)
.nbss 0xb8c 0 0x40 (64)
Total data memory used (bytes): 0x3cc (972) 47%
Dynamic Memory Usage
region address maximum length (dec)
heap 0 0 (0)
stack 0xbcc 0x434 (1076)
Maximum dynamic memory (bytes): 0x434 (1076)
"/var/progs/microchip/xc16/v1.24/bin"/xc16-bin2hex dist/default/production/mpcontrol.X.production.elf -a -omf=elf
make[2]: Leaving directory '/var/home/dave/Desktop/proj/mpcontroller/MPLABXProjects/mpcontrol.X'
make[1]: Leaving directory `/var/home/dave/Desktop/proj/mpcontroller/MPLABXProjects/mpcontrol.X'
BUILD SUCCESSFUL (total time: 2s)
Loading code from /var/home/dave/Desktop/proj/mpcontroller/MPLABXProjects/mpcontrol.X/dist/default/production/mpcontrol.X.production.hex...
Loading completed
and here is the info from the mplabx dashboard for the project
PHP Code:
mpcontrol
Project Type: Application - Configuration: default
Device
dsPIC30F4011
Checksum: 0xD1AE
Compiler Toolchain
XC16 (v1.24) [/var/progs/microchip/xc16/v1.24/bin]
Production Image: Optimization: gcc 0
Memory
Usage Symbols disabled. Click to enable Load Symbols.
Data 2048 (0x800) bytes
Program 16384 (0x4000) words
Debug Tool
PICkit2
Debug Resources
Program BP Used: 0 Free: 2
Data BP Used: 0 Free: 2
Data Capture BP: No Support
Unlimited BP (S/W): No Support
Other Project Info
Data Reserved Memory
Production Image
Program Reserved Memory
Production Image
Control Points.
Java NetBeans Properties
MPLAB X IDE v2.30 - mpcontrol : default
os.name : Linux
os.arch : amd64
os.version : 3.13.0-32-generic
sun.arch.data.model : 64
sun.java.command : org.netbeans.Main --userdir /home/dave/.mplab_ide/dev/v2.30 --branding mplab
java.version : 1.7.0_67
java.vm.version : 24.65-b04
java.runtime.version : 1.7.0_67-b01
java.specification.version : 1.7
netbeans.user : /home/dave/.mplab_ide/dev/v2.30
netbeans.home : /var/progs/microchip/mplabx/mplab_ide/platform
netbeans.projects.dir : /home/dave/MPLABXProjects
java.io.tmpdir : /tmp
user.home : /home/dave
user.country : US
user.language : en
user.timezone : America/Chicago
sun.jnu.encoding : UTF-8
file.encoding : UTF-8
file.separator : /
Java & System Memory
Java Total Memory = 247 Mb
Java Used Memory = 112 Mb
Java Free Memory = 135 Mb
CommittedVirtualMemorySize = 3770 Mb
FreePhysicalMemorySize = 585 Mb
MaxFileDescriptorCount = 0 Mb
OpenFileDescriptorCount = 0 Mb
ProcessCpuLoad = 0 Mb
SystemCpuLoad = 0 Mb
TotalPhysicalMemorySize = 3754 Mb
System Path
PATH = /home/dave/bin:/var/progs/jdk/bin:/var/progs/adk/sdk/tools:/var/progs/adk/sdk/platform-tools:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/var/progs/microchip/xc8/v1.33/bin:/var/progs/microchip/xc16/v1.24/bin
so if you unzip this into directory /home/dave/Desktop/proj/mpcontroller the mplab project posted above should work as is, but I don't recommend it long term.
