Originally Posted by aetos81
Looks pretty cool, what will send the signal to activate the louvers? Will the relay close automatically?
Pete
Right now im planning to use an ordinary fan controller to control the on/off point. By default it will be on when the key is on and when the controller reads a set temperature it will "turn on" and break the circuit for the solenoid which will cause the louvers to open.
