Old 03-23-2015, 09:22 AM   #1777 (permalink)
Astro
Dreamer
Well this is all strange.
I extracted those files to a folder in the mplabx projects directory.
Then in mplabx i created a new stand alone project using that folder.
Added the source and header files from the folder to the project.
Did a clean and build and hey presto it worked.
I hadn't changed anything else in mplabx so i am not sure what i was dong wrong before.
Code:
CLEAN SUCCESSFUL (total time: 51ms)
make -f nbproject/Makefile-default.mk SUBPROJECTS= .build-conf
make[1]: Entering directory `/home/jase/MPLABXProjects/ACInductionController'
make  -f nbproject/Makefile-default.mk dist/default/production/ACInductionController.production.hex
make[2]: Entering directory `/home/jase/MPLABXProjects/ACInductionController'
"/opt/microchip/xc16/v1.24/bin/xc16-gcc"   ACInductionController.c  -o build/default/production/ACInductionController.o  -c -mcpu=30F4011  -MMD -MF "build/default/production/ACInductionController.o.d"        -g -omf=elf -O0 -msmart-io=1 -Wall -msfr-warn=off
"/opt/microchip/xc16/v1.24/bin/xc16-gcc"   UART4011.c  -o build/default/production/UART4011.o  -c -mcpu=30F4011  -MMD -MF "build/default/production/UART4011.o.d"        -g -omf=elf -O0 -msmart-io=1 -Wall -msfr-warn=off
"/opt/microchip/xc16/v1.24/bin/xc16-gcc"   -o dist/default/production/ACInductionController.production.elf  build/default/production/ACInductionController.o build/default/production/UART4011.o      -mcpu=30F4011        -omf=elf -Wl,,--defsym=__MPLAB_BUILD=1,,--script=p30F4011.gld,--stack=16,--check-sections,--data-init,--pack-data,--handles,--isr,--no-gc-sections,--fill-upper=0,--stackguard=16,--no-force-link,--smart-io,-Map="dist/default/production/ACInductionController.production.map",--report-mem
Program Memory  [Origin = 0x100, Length = 0x7f00]
section                    address   length (PC units)   length (bytes) (dec)
.text                        0x100               0x170           0x228  (552)
.const                       0x270               0xff0          0x17e8  (6120)
.text                       0x1260              0x1a60          0x2790  (10128)
.dinit                      0x2cc0               0x174           0x22e  (558)
                     Total program memory used (bytes):         0x43ce  (17358) 35%
Data Memory  [Origin = 0x800, Length = 0x800]
section                    address      alignment gaps    total length  (dec)
.ndata                       0x800                   0           0x1ac  (428)
.nbss                        0x9ac                   0           0x188  (392)
.ndata                       0xb34                   0            0x58  (88)
.nbss                        0xb8c                   0            0x40  (64)
                        Total data memory used (bytes):          0x3cc  (972) 47%
Dynamic Memory Usage
region                     address                      maximum length  (dec)
heap                             0                                   0  (0)
stack                        0xbcc                               0x434  (1076)
                        Maximum dynamic memory (bytes):          0x434  (1076)
"/opt/microchip/xc16/v1.24/bin"/xc16-bin2hex dist/default/production/ACInductionController.production.elf -a  -omf=elf
make[2]: Leaving directory `/home/jase/MPLABXProjects/ACInductionController'
make[1]: Leaving directory `/home/jase/MPLABXProjects/ACInductionController'
BUILD SUCCESSFUL (total time: 1s)
Loading code from /home/jase/MPLABXProjects/ACInductionController/dist/default/production/ACInductionController.production.hex...
Loading completed
Thank you P-hack.
Now i have a foundation for making any minor changes that the forum or Paul might come up with and building the hex file myself.
Paul does amazing work but it is nice to know that i can make minor changes myself.
I am not saying i will but it is nice to not feel reliant on Paul's generous nature.
