Old 03-23-2015, 03:08 PM   #20 (permalink)
herberpower
herberpower's Avatar
Dominates Everything - '88 Honda NX650 Dominator
90 day: 50.55 mpg (US)
Mini scooter - '15 Ride E1
90 day: 615.21 mpg (US)
Conor City 350 E-Bike - '03 Conor City 350
90 day: 907.26 mpg (US)
Maxi Scooter - '09 Vectrix VX1 NIckel Nickel
90 day: 233.45 mpg (US)
Vectra B - '01 Opel Vectra B Elegance
90 day: 27.77 mpg (US)
Originally Posted by RedDevil View Post
Depends on rim design, but steel rims usually have a groove for the notch on lips of hub caps to fall into.
So you can use regular hub caps as a base for an aerodynamic cover, then you can mount and dismount them easily.
Many alloys have straight spokes; if you put a plate on them with tie wraps they may shift out of place easily. Hose clamps might work.
Your 15" alloys look fine for mounting a plate on, especially if the side falls within the outer rim edge.
My alloys bulge outward a bit and do not have an edge like that.
Those 15" wheels look al lot taller than the 14"s...
I previously had these tires with these covers.
one day after going down a mountain. stopped at a car park. 10 minutes had been melted the plastic cover.
an aluminum rim is best for a good cooling.
Car:
Motorcycle:
Scooter:
E-Bike:
