Old 03-23-2015, 03:58 PM   #1 (permalink)
calfianu
calfianu's Avatar
Send a message via Yahoo to calfianu
Chevron trailing edge applications
I am thinking for couple of months now to a possible drag reduction application of this principle: Chevron (aeronautics) - Wikipedia, the free encyclopedia
I imagine that this system that permit a gradual mixing of different layers with different velocity might work to reduce the turbulence of the side mirrors. I wonder if someone tried or heard something.
This time there is no jet on the inside of the tooth-sawed perimeter but outside, the speed inside of this perimeter being zero...
Moving forward with this idea, similar with the utilization of "air tabs" I imagine utilization of such pattern always when the smooth surface has to be interrupted. Instead of make a clean smooth line (like the wheel passage) I imagine using a pattern like this. The intention is to not increase locally the body section.
The Following 3 Users Say Thank You to calfianu For This Useful Post:
aerohead (03-23-2015), BamZipPow (03-23-2015), freebeard (03-24-2015)
