Old 03-24-2015, 02:37 AM   #38 (permalink)
Chrysler kid
5 pin sensor
Zippy - '96 Honda Civic Hx
90 day: 40.77 mpg (US)
Boring - '11 Ford Fusion Sel
90 day: 21.88 mpg (US)
It's not for dimming as it is a constant color.
I Was googling trying to find a low voltage sensor, basically something with an independent power source to illuminate at a programmed low voltage. Anyways ended up buying a cheap $7 tiny volt meter with an independent power source to wire to my secondary o2 sensor readings. It's small enough to hide in plain sight.
I lack the engineering skills to create a sensor to illuminate at less than .9 volts
http://www.amazon.com/dp/B00C58JGE6/...Mini+voltmeter
Current: 1997 civic lx
Past: 1998hx/1996hx/1997lx/1997hx Cali/1997hx
OG lean burn member
My civic thread
