The saturn S series is a popular model to convert. You should be able to find one converted already or a suitable motor and adapter fairly easily.
All the production EVs I know of are direct drive, with sufficiently large motors to compensate for lack of gear selections.
Note, there are plenty of used EV's in the $10-$15k range. It is hard to justify a conversion for simple commuting purposes, unless you get everything you need for a bargain. Decent batteries are many thousands of dollars.
