Originally Posted by Daox
The Matrix and Vibe will not get 40 mpg just cruising. They'll get mid and possibly upper 30s under ideal conditions. If you P&G you'll get more. Same with the Fit (booo short gearing).
Your best bet is probably a Civic HX or Insight. The Echo is probably another one that would work well.
I've seen the term P&G mentioned a few times here. What is P&G? Pedal and gravity?
