Old 03-27-2015, 12:07 AM   #22 (permalink)
oil pan 4
Sub 15mpg is pretty normal for 90s 2wd 6.5L suburban.
I believe they come with 4L80E transmission, which isn't super efficient and they tend to have 3.73 or 4.10 gears.
Check out dieselplace dot com.
I say if you are using trying to flush the transmission get a pan with a drain plug and use the cheap fluid that is only about $10 a gallon.
The coolant heater is in the water jacket, if its working, after you plug it in you should start to hear a crackling, sizzling or hissing sound from the water in contact with the element boiling. If its quiet and not sparking when you unplug it its likely dead.
101Volts (03-28-2015)
