I've only had the car for a couple weeks now, and I'm just getting around to routine maintenance right now, but after that, I'm going to get into aero mods, and guages like MPGuino, scanguage, vacuum, etc. after I research them a bit, but I know little about hooking them up for the VX or what each one specifically reads, so I'll have to look into it more.
I changed the engine and trans fluid, so next up, I have a new air filter, and I might just take the entire intake off to clean out the EGR valve, IACV, and entire intake assembly where the EGR ports are. What about the spool valve? Does that ever get dirty or need maintenance done to it?
It just seems odd to me that with the tires at 50psi and cruising at 65mph, that I'm popping in and out of lean burn on level ground. I figured it probably wouldn't do that until 75 or so, but I'm not experienced on that matter. On level ground, how fast can you guys go before you fall out of lean burn in mph and RPMs?
