Don't forget the scangauge! You are OBDII so it's simpe plug and play. 5th gear swap will kill cruise control of you have it. Do a full grill block and get a factory air dam if you don't have it already for bottom cooling. If/when you need to do the valve cover gasket, get an aluminum one with all the bolts off a 95 and older car. The plastic ones tend to warp and all the valve cover gaskets in the world can't keep them from leaking. Coils dont usually go bad on those cars and aftermarket can be questionable. Saturnfans.com has a lot of info on testing resistance of the coils to tell if they are bad. There is also the arc test when it's dark out. I tried the 5th gear swap and destroyed my trans from over tightening the nuts, swapped in an MP2 SOHC trans and loved it! All I had was trans swap, vacuum gauge and slow driving and was getting 45mpg.
Can't wait to see what you do to yours
-Mike
2007 Ford Focus ZX5 - 91k - SGII, pending upper and lower grill bocks - auto trans
1987 Monte Carlo SS - 5.3/4L80E swap - 13.67 @ 106
2007 Ford Focus Estate - 230k - 33mpg - Retired 4/2018
1995 Saturn SL2 - 256K miles - 44mpg - Retired 9/2014
Cost to Operate Spreadsheet for "The New Focus"
