Old 03-28-2015, 10:44 PM   #14 (permalink)
jeffcat
jeffcat's Avatar
SuperVX - '94 Honda Civic VX
90 day: 52.17 mpg (US)
Originally Posted by OG VX View Post
Hey, made this video today for the question posed in this thread. Hope it helps!
Thanks for the vid. It helps with the visualization. I hear what you mean by there being multiple stages as there are times where it's hard to tell if I am or am not in lean burn probably because I'm in an "in between" stage. I can kind of tell when it's in lean burn, but it's easier to tell when I'm cruising, it falls out with the definitive pick up in power, then for a split second, I let off the gas, then get back into it to unload the engine a bit and then it feels like I need twice the throttle input to keep it at speed since it's in full lean burn and can't maintain the speed it was going with that power.
I'll have to look up how to set up the vac guage and and MPGuino. I know I want to set them up sometime, so I'll have to get on that task sometime in the future after I get a few things sorted. Where did you get that particular vac guage at?
