Old 03-29-2015, 11:08 AM   #202 (permalink)
Daox
So, I've been working on the Metro's hiccups lately. It has a few of them.
First one was I had no lowbeams. I had highbeams, and I had DRLs, but when I turned on my lowbeams, I got just running lights. A bunch of google searching lead me to a defective DRL unit. That is this thing. Its under the dash mounted to the steering column. I removed it to take a look. There was no visible issue with it, one of the chips in it must have failed.
So, I looked online again and found a way to simply bypass it, and did that. I just took a piece of solid household wiring, hammered the ends flat to fit into the connector, and shoved them in. Then, I wrapped it with tape to avoid any shorts. I shoved it back up under the dash and I have lowbeams again, yay. I also don't have DRLs anymore, but those turn off anytime I EOCed anyways... haha.
ID:	17250   Click image for larger version
ID:	17251   Click image for larger version
The Following User Says Thank You to Daox For This Useful Post:
Insight for life (03-29-2015)
