I admit I didn't read through all 106 pages here but hope this is the appropriate place to ask.
I am trying to load this on an arduino Uno but am having no luck. I admit I really don't have a clue about coding. Building the hardware is no problem though.
When I copy / paste the code and try to verify it there's always lots of errors as pasted below.
If anyone can help or point me in the right direction I would be really appreciative of that. Thank you!
Arduino: 1.6.1 (Windows 7), Board: "Arduino Uno"
sketch_mar29a.ino:51:17: error: conflicting declaration 'typedef uint8_t boolean'
In file included from sketch_mar29a.ino:51:0:
C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/Arduino.h:117:14: error: 'boolean' has a previous declaration as 'typedef bool boolean'
typedef bool boolean;
sketch_mar29a.ino:91:15: error: 'prog_char' was not declared in this scope
sketch_mar29a.ino:91:27: error: 'str' was not declared in this scope
sketch_mar29a.ino:397:1: error: 'prog_char' does not name a type
sketch_mar29a.ino: In function 'void setup()':
sketch_mar29a.ino:403:2: error: 'displayFuncNames' was not declared in this scope
sketch_mar29a.ino:432:44: error: 'getStr' cannot be used as a function
sketch_mar29a.ino:434:44: error: 'getStr' cannot be used as a function
sketch_mar29a.ino: In function 'void mainloop()':
sketch_mar29a.ino:541:37: error: 'getStr' cannot be used as a function
sketch_mar29a.ino:549:42: error: 'getStr' cannot be used as a function
sketch_mar29a.ino:553:45: error: 'getStr' cannot be used as a function
sketch_mar29a.ino:559:23: error: 'displayFuncNames' was not declared in this scope
sketch_mar29a.ino:559:47: error: 'getStr' cannot be used as a function
sketch_mar29a.ino:564:42: error: 'getStr' cannot be used as a function
sketch_mar29a.ino:569:23: error: 'displayFuncNames' was not declared in this scope
sketch_mar29a.ino:569:47: error: 'getStr' cannot be used as a function
sketch_mar29a.ino: At global scope:
sketch_mar29a.ino:628:15: error: redefinition of 'char* getStr'
sketch_mar29a.ino:91:8: error: 'char* getStr' previously defined here
sketch_mar29a.ino:628:15: error: 'prog_char' was not declared in this scope
sketch_mar29a.ino:628:27: error: 'str' was not declared in this scope
In file included from sketch_mar29a.ino:49:0:
sketch_mar29a.ino: In function 'void LCD::init()':
sketch_mar29a.ino:755:22: error: variable 'chars' must be const in order to be put into read-only section by means of '__attribute__((progmem))'
Error compiling.
This report would have more information with
"Show verbose output during compilation"
enabled in File > Preferences.
1998 LX with a full HX swap + VX transaxle.
