You can put the antenna back on. Take off the trim along the front/top of the passenger door opening, take out the rear bolt of the antenna base, loosen the front bolt, and tilt the base rearward. You will then be able to screw the antenna back into the base and cover it under the door opening trim, then tighten the front base bolt
I ran a 94 h body on the same commute as the sc1. The sc1 could get 37mpg as easy as my olds 88 could get 25
