Originally Posted by archat68
BTW the car is 2008 build, runs a CRDI engine. Has OBDII but the protocol followed by the manufacturer is proprietary and the SGII doesn't works with it.
Yoou can try to find fuel consumption signal going from your ECU. Many new ECUs have one. I've used it to hook up MPGuino to my BMW tds. It worked like a charm.
I can;t tell you if the signal from the injectors of CRDI engine will be sufficient for MPGuino, but I may try it with my wife's Cirtoen with HDI (similar to CRDI) engine. But don;t expect any quick results, I'm running out of time recently.
