Old 03-31-2015, 01:34 PM   #4 (permalink)
freebeard
SCIgen - An Automatic CS Paper Generator
https://www.google.com/search?q=bogus+science+papers
Mac OSX Summarize Text set to lowest setting and Sentences:
Making a metaphoric comparison with the intention to expose it more clearly for a better comprehension of this innovative technical detail, it would be similar to the trajectory and motion of a dynamic flow compared with a rope (extended) that passes through the system would have now a knot (without obstructing the flow), so the complete way of the flow at the imploturbocompresor system have three direct ways and between make two different turns; direct way (entrance) - turn - direct way (implocavity) - turn - direct way (exit), all this in a 1 simple circular move system concept.
...and set to Paragraphs
*8-X/Y Thermodynamic CYCLE - Way Steps:
1)1-Compression / bigger
2)2-Turbo 1 cold
 3)2-Turbo 2 cold
 4)2-Combustion - circular motion flames / opposites
 5)2-Thrust - single turbo & planetary gears / ying yang
 6)2-Turbo 2 hot
7)2-Turbo 1 hot
8)1-Turbine / bigger
Originally Posted by Xist
I do not have any idea where to start trying to understand this. Who has some good cat pictures?!
http://justacarguy.blogspot.com/search/label/caterpillar%20tracked%20vehicle
Xist (03-31-2015)
