Old 03-31-2015, 11:36 PM   #16 (permalink)
serialk11r
Originally Posted by rmay635703 View Post
The kit had a wideband which you put in place of your narrow 02 and then converted it to narrowband for your ECU to be happy, you could then adjust where the narrow band AFR thought STOICH was centered on using the dial.
Anyone remember what this plug was? I can't seem to find the thread. (it wasn't a simple efie)
It's called a narrowband emulator. Innovate LM-1 is the first that shows up on Google. The problem with using one of these is that you can't make the engine run that lean since the idle will have problems.
