Originally Posted by firehawk618
I am trying to load this on an arduino Uno but am having no luck. I admit I really don't have a clue about coding. Building the hardware is no problem though.
I haven't worked much with the Arduino IDE nor this software but I've compiled Arduino code and coded as a software engineer for years....
I'd guess somethings wrong in your include environment. Make sure you have the right version of the IDE and settings on the board, processor type all set as documented in the project code. Can you compile other Arduino IDE projects? Try a simple one.
I looked a while and couldn't find the code you are using.
Allan
