re: DRL
My VX had a similar issue, If you take the unit apart you should see the circuit board.
On the civics it is an issue that some or all the solder points get fractured.
Simple cure heat up a soldering iron and touch the points, add solder if needed.
Mine had 3 bad points and works just fine now.
2000 Insight MT 106K Citrus A/C
