Old 04-01-2015, 07:02 PM   #18 (permalink)
aerohead
full bottom
Originally Posted by rollercoaster View Post
I would think the combination of a full belly pan and lowering would increase drag because of the pressure differentials from top compared to bottom. In essence, you're creating suction -yes?
OP -Any data on lowering in conjunction with a full bottom pan?
The VW Flow body has a full,smooth belly and undergoes a 9.5% drag INCREASE when dropped to zero clearance.
As to suction,I'm not sure.
The pan's job is to eliminate turbulence and deliver laminar flow to the wake,or to a diffuser,which can decelerate the flow and deliver a higher base pressure,cutting pressure drag.
