Old 04-01-2015, 07:06 PM   #19 (permalink)
aerohead
50mm
Originally Posted by Vekke View Post
I have also studied this long time ago and if I remenber correctly if you go lower than 50mm clearance it does not help anymore :/.
You can try to find details of the Bugatti veyron as it lowers at high speeds.
50mm is an interesting animal.The PROBE-IV,with the front airdam deployed gives the car about 1.92-inches ( 48.76mm) actual ground clearance.Ford could have chosen any clearance.It's interesting that they ended up with around 50mm.
