Originally Posted by Chrysler kid
I'm at 275 sitting on the top side of half of a tank of gas. The needle tends to fall very quickly after half tank and I fill up at a quarter tank. I'm sure I would gain the most economy the less fuel I carry on board however I do not like the added stress and heat on the fuel pump. Im sure if I took out my two 12 inch subwoofers it would make a difference too lol.
I'm also running 10w30 synthetic, again I should switch to a lighter weight once summer hits full swing
Next tank I will try some marvel mystery oil. See if that snake oil does anything
The top half of the tank is around 7 gallons and the bottom half is somewhere around 4-4.5, that's why.
