Old 04-02-2015, 04:00 AM   #14 (permalink)
AndrzejM
AndrzejM's Avatar
Berta - '97 BMW 318 tds Compact
90 day: 62.03 mpg (US)
Charlie - '07 Citroen C4 Grand Picasso Exclusive
90 day: 37.58 mpg (US)
Corsa - '05 Opel Corsa C
90 day: 53.22 mpg (US)
Mruczek - '03 Audi A2
90 day: 60.61 mpg (US)
That's because PNP transistor requires different signal than NPN - NPN with zero signal on the base will cut the current and PNP will cut the current with the high setting. That's why LCD was not dimmed but was brightened to the max. To make it work with a PNP transistor you would need to change the code to dimm LCD with the "high" voltage.
Gerhard Plattner: "The best attitude is to consider fuel saving a kind of sport. Everybody who has enough money for a strong car, can drive fast and hit the pedal. But saving fuel requires concentration, self-control and cleverness. It's a challenge with the nice effect of saving you money that you can use for other more important things."
The Following User Says Thank You to AndrzejM For This Useful Post:
firehawk618 (04-02-2015)
