Old 04-02-2015, 06:19 PM   #484 (permalink)
BamZipPow
T-100 Road Warrior
BamZipPow's Avatar
BZP T-100 (2010) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 24 mpg (US)
BZP T-100 (2011) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 23.66 mpg (US)
BZP T-100 (2009) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 19.01 mpg (US)
BZP T-100 (2012) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 25.45 mpg (US)
BZP T-100 (2013) - '98 Toyota T-100 SR5
Last 3: 25.79 mpg (US)
BZP T-100 (2014) - '98 Toyota T-100 SR5
Last 3: 23.18 mpg (US)
BZP T-100 (2015) - '98 Toyota T-100 SR5
Last 3: 23.85 mpg (US)
BZP T-100 (2016) - '98 Toyota T-100 SR5
Last 3: 17.62 mpg (US)
BZP T-100 (2017) - '98 Toyota T-100 SR5
90 day: 20.78 mpg (US)
BZP T-100 (2018) - '98 Toyota T-100 SR5
90 day: 20.19 mpg (US)
BZP T-100 (2019) - '98 Toyota T-100 SR5
BZP T-100 (2020) - '98 Toyota T-100 SR5
2012 Scion iQ - '12 Scion iQ Base
Send a message via ICQ to BamZipPow
Wink
I will keep in mind that type of ingenious technology if I come across the materials fer cheap and figure a way to implement them.
Fer now, I only have the dead wiring harness that I can put to use...which is basically free.
I did notice yesterday's run was rather smooth with the new tire installed.
I've been also looking/researching other replacements fer the air bag when the time comes to replace it due to age/wear. The Firestore Work-Rite suspension was too big and cutting it down would've reduced it's capability to function as designed. I ended up returning it today. I will need to contact Timbren about the axle-less suspension as it looks promising to use their 400lb rated spring as the air spring replacement in Dark Aero. I will probably have to install a bump stop fer the rebound. I will lose the adjustability of the air bag spring though.
Axle-Less - Timbren Industries Inc. Suspension Products
Dark Aero-The world's first aerodynamic single wheel boat tail!
The Following User Says Thank You to BamZipPow For This Useful Post:
aerohead (04-02-2015)
