Mine is 16MHz but I did comment out the "use with 20mhz" block and uncomment the "use with 16mhz" block. Do I need to do something else as well?
I also used the source at
http://opengauge.googlecode.com/svn/...no/mpguino.cpp which is what the wiki said was the "official" code. Is there better code to use?
