Originally Posted by thewanderer
Mine is 16MHz but I did comment out the "use with 20mhz" block and uncomment the "use with 16mhz" block. Do I need to do something else as well?
I also used the source at http://opengauge.googlecode.com/svn/...no/mpguino.cpp which is what the wiki said was the "official" code. Is there better code to use?
Subscribed.
What you say is strange, MPGuino miles / fuel used being way off from what it displays.
I haven't gotten a tank through mine yet but have a feeling MPGuino is going to be very optimistic in my tank MPG calculations.
I really doubt I'm averaging 50 right now.....
Curious to see what you figure out.
I ended up installing a pre-assembled unit that I had purchased. I can tell immediately the calculations are different and seem MUCH more realistic vs the code I had been running.
I was running the one that's on the wiki page, but as AndrzejM pointed out, that code is very old.
I have to wonder if that's what your issue is?
