Yeah, I will definitely be removing the seat to work on it. Going to do the clutch, brake and kill switches all at the same time, so I'll be under there a while
***edit***
Only had time to put the new EGR valve on, but it made a big difference, and it holds lean burn perfectly and there's no hesitation when I barely give it gas. I bought the Accord V6 version BTW, and it fit and functioned great. Not sure what the difference is between the 4-cyl & 6-cyl versions on the Accord EGR, but it looked identical to the one I had bought off IC and put on Turtle awhile back, and it was 52 bucks shipped (with the gasket).
