Originally Posted by Asanelli
So basically i am looking to possible purchase a newer generation ie: 2010+ Toyota Tacoma Double Cab 4x4 4.0L 5 Speed Automatic.
However before doing so i want to check with the gurus here and see if it is possible to achieve better than OEM/EPA ratings.
With that regard the truck in question that I am thinking about is rated for 16 City and 21 Highway.
So my question is do you believe it is possible to attain 25 MPG Highway. As i currently drive 50 miles round trip everyday for work.
My anticipated modifications would likely be the following.
Aero Bed Shell (DIY Kammback style)
Folded Mirrors
Max Out Tire Pressure
Front Air Dam
Front Grill Block
Electric Fan
Full Flat Bottom
Rear Fender Well Skirts (maybe)
Smooth Wheel Disks (maybe)
Scan Gauge
Please let me know what you thoughts are.
At what speed are you hoping to hit 25mpg highway? I would venture to guess you'd be close to that in stock form at 50mph. If you are hoping to hit that mpg at 70+ you would likely hit it or come close with your list of mods. I would add light synthetic fluids to your list, especially if you don't plan on much towing. Do some research to come to a conclusion on what you're comfortable with for your application in that regard.
