Originally Posted by mikeyjd
At what speed are you hoping to hit 25mpg highway? I would venture to guess you'd be close to that in stock form at 50mph. If you are hoping to hit that mpg at 70+ you would likely hit it or come close with your list of mods. I would add light synthetic fluids to your list, especially if you don't plan on much towing. Do some research to come to a conclusion on what you're comfortable with for your application in that regard.
As far as speed between 55mpgh and 75mph.
Ah yes i would likely go full synthetics.
My intended usage for the vehicle would be to use it for camping but need to commute as well at least initially. Until i buy an older civic.
