Old 04-06-2015, 03:05 PM   #7 (permalink)
Asanelli
Noobie
Originally Posted by elhigh View Post
If you can live without the 4x4 (Colorado, maybe not), a 4x2 with a limited-slip diff will get you out of a lot of tight situations while providing much better fuel economy the rest of the time. You're going to sacrifice a lot of fuel economy and money the rest of the year for the limited amount of time you need all four wheels pulling.
For a fair amount of space, full-time AWD and better fuel economy in general, have you looked at something like a Subaru Outback? One word of warning: avoid the EJ25 engine. Aside from that they're pretty good.
There's a guy here with a Forester (he calls it Forester Whitaker) that beats 25mpg every time, and cracks 30mpg pretty often. The 2011+ model Foresters got the new FB series engine, which is supposed to be quite a bit more reliable than the EJ. It also made the switch to timing chains instead of belts, which is important to me in particular.
That thought about getting a 2wd truck has cross my mind, and then just getting an air locker for when it gets real hairy.
