Thanks for the compliments! I will have to check out all those links, thank you.
Timing belt and water pump have less than 10k on them, i checked belt and it looks new.
I got started working on it today, so i went to the honda dealership for everything. I got full synthetic 5w30 honda oil & filter, MTF new formula, air filter and crush washers. I wanted a fuel filter but they were all out of stock.
The old man i got the car from i think only ever had the timing belt done and some light general things done at the dealer. Everything is honda down to the blue coolant and i plan on keeping it that way because my last rusty civic wasnt even a honda anymore, it was more like a duralast pos.
I guess ill make a build thread even though i don't plan on doing anything crazy.
I do have more questions: What are the best tires for MPG? doesn't some company make fuel saving tire tread design?
I think when its cold i can hear a faint exhaust leak so i must check that out soon. isn't it common for the manifold to crack on honda's?
what bluetooth obd2 thingy do you use for an iphone 6?
How did you figure you needed a new o2? Did it show a code?
