Hello all. My names Ryan and I picked up a 92 civic vx in September of 2013 from the dealer I work at. Day I bought it:
work done since purchase:
Muffler delete
Full oem tune up(plugs cap rotor wires fuel filter)
Trans fluid, brake fluid, clutch fluid and coolant drain and refill with oem fluids
Oil changed every 2-3k
PCV valve replacement breather box removal and cleaned out, replaced o-rings
Distributor replacement(bearing went bad)
Starter replacement
Alt replacement
Valve adjustment
Tein basis coilovers
Control arm bushing replacement
Oem thermostat
Rear hatch struts
B&M Short shifter w/ energy bushings
4300K hids
Leds where ever possible
Updated 5-wire O2 sensor NTK 24300
Hollow CAT
Was getting 50mpg when I first bought the car but than slowly decreased over the past year. Valve adjustment and new O2 sensor helped the most with the hesitation and random misfire issue I was having. Haven't gone through a full tank yet so can't confirm anything yet. Will start a fuel log once I get through my current tank.
Only current aero mods are the deleted passenger mirror which was already done when I got the car and the fact that it is lowered. Plan on installing a coroplast belly pan and grill block soon. Also have to wire up the mpguino. Been seriously slacking on that. Bought this car as a winter beater because I don't want to drive my accord in the winter. EG hatches are one of my favorite cars out there so it's hard for me not mod it and enjoy it.
Currently how the car sits:
