Thread
Correct D15Z1 leanburn info
04-07-2015, 11:25 AM
56
permalink
WD40
EcoMod Proof of Concept
WD-40's Insight
- '00 Honda Insight
Gen-1 Insights
90 day:
56.04
mpg (US)
WD-40's Mirage
- '15 Mitsubushi Mirage ES
90 day:
46.05
mpg (US)
WD-40's Sonata Hybrid
- '17 Hyundai Sonata Hybrid Limited
jeffcat, you are correct.
There should only be the lower PCV valve the upper is simply an elbow, remove the valve cut off the bottom remove the guts replace as an elbow.
2000 Insight MT 106K Citrus A/C
The Following User Says Thank You to WD40 For This Useful Post:
jeffcat
(04-07-2015)
WD40
View Public Profile
Send a private message to WD40
Find More Posts by WD40
