Old 04-07-2015, 06:44 PM   #33 (permalink)
oil pan 4
The diesel and remade 700R4 will replace the 454/TH400 in this C2500 eventually.
The diesel will get its mild steel cross over pipe replaced with 2 inch 316alloy stainless and waste gate with side exit screamer pipe. It has to have a waste gate because when I go back down to sea level it will hit over 20psi and that's too much.
Then since the body on this C2500 I will install all the high voltage accessories I wanted to put on my old suburban but never did because I knew it would be a pita to move it all over.
