Most of the exhaust manifold cracks occur around the primary oxygen sensor on the exhaust manifold around 180k miles regardless of vehicle. Cast iron seems to have a certain amount of heat cycles before they stress and crack.
My hx cracked at the o2 sensor and would only trigger a check engine light when the car was running and the hood was popped
You should also clean out the egr ports, there is a write up around here somewhere
Current: 1997 civic lx
Past: 1998hx/1996hx/1997lx/1997hx Cali/1997hx
OG lean burn member
My civic thread
