Old 04-09-2015, 02:45 AM   #75 (permalink)
Focus-Ak
n/a - '05 Ford Focus ZX3
Originally Posted by MisterMundane View Post
... My glide mpg isn't as high as I would expect, gliding from 110 km/h down to 85, it's around 250-350 mpg. More so closer to 250. Sometimes jumping around 300. Seems low to me, no?
What is your ambient air temperature these days?
So this is 15 MPH coast-down from about 68 to 53 MPH. And dividing those numbers by the appropriate MPG number, you are idling at 0.21 gal/hr. That is about the lowest instantaneous gal/hr I see on my Focus (on rare occasion 0.2 or 0.19), so I presume your idle is dropping to around 700 RPM or a bit lower.
I suggest setting up a second page of instruments on your UltraGauge, showing 8 instruments (see reason below). You can deactivate the other 6 pages so that you can easily flip back and forth between the page you already have with 6 instruments and a new one with 8.
In one of the two new extra instrument spaces you set up gal/hr. If you don't have a tachometer on your dashboard, you can put RPM in the other new space, and you will find that to be good hypermiling guide too. I watch the gal/hr reading a lot. It tells me how well the engine is warming up, and how well at a given time pulsing and gliding will work for me. I have found that gal/hr at idle does not correspond directly to coolant temperature. The Focus ECU has a mind of its own, a for the temperature of the moment sometimes the idle gal/hr isn't as low as it seeming should be.
Also, on this webpage you can punch in your car model and year and get a list of expected available UltraGauge instruments, in the order they appear in the UG's menu. Handy to have:
http://ultra-gauge.com/ultragauge/su...augelookup.php
As a tool to make setups and setup changes easier I put that list in the A column of a spreadsheet, and use the B and C columns for my two pages of instruments. For each instrument I am putting on the page, I enter my desired position number. Saves a lot of fumbling around and retries.
