Swapped out my recently malfunctioning EGR valve halfway through this tank, now it's back to low-accelerating and holding lean burn smooth as silk!
I keep hearing that you have to buy the Accord 4-cyl version to use on the Insight, but since the V6 version was cheaper I bought that one. The base was a perfect match, and although the plug was a little awkward because it's orientation is a little off, it still only took a couple of minutes to install, and it works perfectly.
Less than 52 bucks, with a gasket:
Standard T Series EGV658T EGR Valve | eBay
Does anyone know if I can wire the compressor up to a
Cheapo, just buy one!
