Where does it leak oil. That is, where are the exact leak locations? To much oil residue to tell? Clean off the engine and then you can maybe tell. Head gaskets don't usually leak oil. But rocker arm seals, and oil pan seals do. Try checking those. Also a loose or cross threaded oil pan drain plug could be the culprit or no seal on the drain plug. Do a LOT of inspecting and analysis before doing a head gasket job. And then you need to check for secret recalls or secret "warranty" coverage. Don't expect the dealer to look out or you.
