Thanks for the info.
Here's a shot of MY van. As you can see the fiberglass top adds about 4" of height but's flat on top (has ridges just like a truck bed but is level side to side and front to back other than that). I think that makes my point of "maximum camber" the upper rear corner right?
Here's an idea of what I'm contemplating up front but think a curved air dam, from flush with the front bumper's foremost bottom edge at the center to flush with the inner fenders at the rear, and reaching from 1-2" inboard of the tire's outer edge on each side would be a better bet. I'll likely extend it an inch or so below the lowest point of the suspension which is quite low on the twin I-beam Ford suspension but thankfully my front overhang (from tire to bumper) is very short so the reduced ground clearance shouldn't matter much and it will likely still be 4-5".
Here you can see the minimal OE air dam. It's cut about 2" short on each side of reaching the tires at all, much less their outer edges. I think keeping the width about 2" narrower than the overall tire width (passenger outside to driver outside) should cut down drag without adding to wake. I can't decide if curved or straight would be better. I'd normally think curved but with such a square front-end there may be more to it...?
I used the aero&rolling resistance calculator. Tell me what you think of my inputs and the
output. 5000 lbs is a rough guess at this point but not too far off I'm afraid as shipping weight for this guy is 4300 or so and the top adds a couple hundred and the interior has some insulation and paneling added. I modified the Cd from .48 due to the top and lowered both the engine efficiency and drivetrain efficiency due to the truck-like components here. Big heavy C6 automatic chief among them. Rolling resistance is due to heavy load range E tires (not in pics, appointment for installation is Thursday) that I did actually choose for their efficient design and the fact that I'm a religious pressure-checker.
