Originally Posted by Articus
Just put together the controller board. Is it testable without the powerboard? Right now I have controller board, 0-5K pot, and current sensor plugged in. My PWM output at R17 is flatline. The PWM signal on pin15 of the Atmega 168 is also flatline 0V. I've gone through and checked the supply voltages at the 6W converter, the 12V in, and the LM7805. All are correct voltages at 12V and 5V for the latter.
Also I am getting errors trying to download RTD explorer. Says something about not being able to find bobert...Can anyone help?
Thanks!
Are you using a preprogramed chip from Paul? If not, have you successfully loaded the unified firmware?
Index of /firmware/cougar-v1.11b/hexfiles-m168
Also when loading firmware for the first time the fusebits need to be set, see mora's post:
http://ecomodder.com/forum/showthrea...tml#post399312
