Old 04-12-2015, 08:41 AM   #8 (permalink)
oldtamiyaphile
oldtamiyaphile's Avatar
UFI - '12 Fiat 500 Twinair
Team Turbocharged!
90 day: 40.3 mpg (US)
Jeep - '05 Jeep Wrangler Renegade
90 day: 18.09 mpg (US)
R32 - '89 Nissan Skyline
STiG - '16 Renault Trafic 140dCi Energy
90 day: 30.12 mpg (US)
Prius - '05 Toyota Prius
90 day: 50.25 mpg (US)
Premodded - '49 Ford Freighter
90 day: 13.48 mpg (US)
F-117 - '10 Proton Arena GLSi
Pickups
90 day: 37.82 mpg (US)
Ralica - '85 Toyota Celica ST
90 day: 25.23 mpg (US)
Sx4 - '07 Suzuki Sx4
90 day: 32.21 mpg (US)
F-117 (2) - '03 Citroen Xsara VTS
90 day: 30.06 mpg (US)
What happened to the VW exactly? And how much is that repair?
The cylinder head on 5cyl T5's is known to crack, the fuel rail is in the head and let's diesel into the oil (also causes a misfire underload). It's a $18K repair through VW, not much less through an independent, and while the engine is out you may as well replace the clutch and DMF, and I think I need a driveshaft, possibly do the water pump, before you know it you've spent a massive amount.
The manual gearboxes are known to go, as are camshafts and injectors. Too many 'known issues' and all of them extra ordinarily expensive to fix, particularly as VW need special tools for everything.
I'm seriously looking at for T3 (Vanagon) as my primary work van, I'd restore and mod it while I have the Kangoo (which I'll likely only keep while the warranty lasts). I'd have 5.7 cubic meters in a smaller package than the T5, stick a Subaru in the back, and a vehicle I could actually fix myself. The economy wouldn't be great, but I suppose I could use s Syncro front end for a hybrid set up. This would all be possible for less than the cost of any mid size new van.
