Old 04-13-2015, 11:55 AM   #264 (permalink)
Xist
Funny, aluminum is supposed to be lighter! It must be far thicker, as I suggested elsewhere. How much of a difference does three pounds make?
They are also supposed to dissipate heat faster.
The Al pan is rated 36 lb-ft and steel is forty, which is pretty close to me.
Put a Quikvalve on it the first time you change the oil and you should never worry about it again!
